Search Forums | Classifieds (42) | Skins | Language
Pto gear lash from below/ How are you supposed to measure for shim thickness?
huronwrench
Posted 2/23/2019 17:44 (#7339654 - in reply to #7339442)
Subject: RE: Pto gear lash from below/ How are you supposed to measure for shim thickness?
Ontario Canada
On those pto's your supposed to take the shifter cover off and stick a dial indicator on the pto gear. Rock the gear back and forth. Supposed to be between 6 and 12 thousands of free play. Take a shim out if too loose, add one if too tight. One thick and one thin gasket is a good starting point
