... how doe a 12 tooth pinion gear fit in where a 9 tooth used to be? This is listed as a replacement for a 3020, 4010, 4020, 4030 4230 and 7700 combine with GAS OR PROPANE ENGINE.
does all those clocking holes move the pinion up or down for proper clearance, the mount is eccentric?
