| Ca360 - 2/16/2019 07:48
I think you stated in an earlier past you were setup for 20 inch spacing also. I would take advantage of the 20 inch spacing by using adapters to pipe thread then pipe thread to a standard tee jet nozzle body. If you run the smaller flood jets at higher psi they tend to make more fines, more drift. This has been what works with our silver wheels.
It's plumbed for 20's but would have to add the richway valves across the boom. Still not sure what I will do but that might get expensive? |
