Classifieds (92)
Primer/paint to use on mild steel with dry fertilizer
Machinery Talk
m18dromader
2/16/2019 08:25 (#7323898 - in reply to #7323780)
RE: Primer/paint to use on mild steel with dry fertilizer
Austin MN
You could take use zinc phosphate as your primer. It's used in aviation all the time as a corrosion preventer. Would not be cheap though.
I probably wouldn't use slip plate. It works great in on non corrosive materials but it will scrape off kinda quickly with fertilizer.
You might ask case what they used from the factory. I'm willing to bet it was a 2 part epoxy paint as well but may not hurt to ask
winner2011
: 2/16/2019 07:42
Josh in Pa
: 2/16/2019 07:54
m18dromader
: 2/16/2019 08:25
brad c
: 2/16/2019 08:48
HardWay
: 2/16/2019 10:05
brentnz
: 2/16/2019 15:20
buschwacker
: 2/16/2019 20:25
mohr-power
: 2/16/2019 22:07
Thanks for the replies NT
winner2011
: 2/16/2019 22:47
ibanez
: 2/17/2019 14:44
