just a tish NE of central ND |
TURBO charger going bad?
Id be pulling hoses and pipes and looking inside the air intake and beyond the turbo downstream side to see if the turbo seals are bad and leaking oil.Pull the air pipe (between the turbo and air to air exchanger if it has one)if it is oily inside your turbo seals are going bad and you turbo is probably on its last legs. |
