Posted 2/14/2019 22:07 (#7321639 - in reply to #7321533) Subject: RE: 4630 Quad Range Pto/clutch issue
Northern Ks
Had same year and trans, was on tub grinder that slugged and killed engine. Operator forced slug through with pto . Next tub grinding season the pto would not work, used tractor for farming for and seemed fine. But started noise in rear end and had it split to fix and pto clutch material every where. Hope you have linkage problems.
