Posted 2/14/2019 16:55 (#7320846 - in reply to #7320774) Subject: RE: F150 battery drain part 2
nw ohio
Put your meter on volts and probe both sides of the fuses, one at a time. Meter will show volts on a fuse that has power going thru it. There is a voltage drop on the fuse when power is going thru it.
