Search Forums | Classifieds (6) | Skins | Language
Stuck loader pin
WAYNE0224
Posted 2/14/2019 19:28 (#7321198 - in reply to #7320578)
Subject: RE: Stuck loader pin
west central ohio
I had a loader pin on a case 621 that took a 50 ton press w heat, w hammering, etc. it almost spread the loader arms and the back of the bucket it was so tight. Im kinda seeing a lance being needed in your case. I also know that a 3/4 nf thread will only hold about 40 tons when using grade 5 nuts to pull, Dont ask how far the otc hyd puller flew when it let loose. Im not real sure about a 1 inch threaded pulling rod with 100 tons. At this point you could destroy something on the loader arms, as im not sure they handle flex very well. Im kinda thinking they just snap. Good luck
