Posted 2/14/2019 14:47 (#7320636 - in reply to #7320446) Subject: RE: J&M Grain Cart Height & 1660 Combine
Eastern Nebraska
You should be fine.
I have a 875 with the same size tires, when I bought the 875 I had a 1991 1640 with 24.5 tires on it and it worked fine. I did shorten the rubber flap on the end of the unloader tube by about half to get additional clearance but I could load the cart full no problem.
