Posted 2/14/2019 22:24 (#7321666 - in reply to #7319847) Subject: RE: Kenworth AG 100 suspension
Northern Ks
Look for used aluminum legs at salvage yard and swap out, the steel ones always held moisture and corroded the aluminum blocks and through bolts. Mine was bad enough to get cut off out to cut bolts out from inside, then had to replace blocks. Spent twice the time to repair as would to swap.
