Washington, Kansas & Lincoln, Nebraska | atc70 - 2/13/2019 21:34
Worth a quick try, is check bad outlet and ones near it to see if any work on one half but not the other. If so, then the break away tab may have failed and that is the outlet that is the problem. Easier explained if I drew a picture, but that's too much work for me.
Thanks! I know what you're talking about and was thinking the same thing. |
