Posted 2/13/2019 16:56 (#7318634 - in reply to #7318571) Subject: RE: HH>>Update
Pickens
Listen here...you messing with me??
Just how many double negatives is that??
but what I read did not indicate failure to NOT run.
Good Luck,..:)
CF
Edit to Add>>Hay Hud, if no-go on the above, you may have that infamous fuse box that has the fuel pump relay built in...have to replace the entire item, best of my knowledge...
