North Central Kansas | no I do not. But in the same token I usually make 3 rounds on the corners so I don't have to break it hard to get turned around. 7240. It does not know that planter is back there, nor the 30' GP box drill I pull in the fall.
If you turn the front tires around to where they are spaced out further, then you can turn tighter. But then you might have the front tires making a different wheel track then the rears, thus planting in the tire tracks more. Its really more tractor then I need, but the $ was right and if I want to ever go bigger I can. Also I know I could get most of my $ back with this old girl if I was to sell it. | |
