I needed to cut some thin wall brass. It goes on my K&T mill so oil doesn't run down a shaft. When I got the mill this was missing. It leaked oil bad. I don't have a parts book for my mill. I found one on line for a different model. There are two of these on the mill and they had the same part number. So I copied the one I had. The oil leak slowed down but was still there. Took it all apart again and saw the part I made wasn't tall enough. So I made this one 1 1/2" longer. It didn't leak when I turned it on and ran it. So I hope I can call this fixed.
Cutting thin wall anything can be a problem. The last cut you want as big as your lathe can do. This way your part is self supporting as you cut. If you take a light cuts it may not stay round.
Keith
Video of the cut.
(2019-02-12 22.45.36 (full).jpg)
(2019-02-12 22.23.17 (full).jpg)
(2019-02-12 22.24.35 (full).jpg)
(2019-02-12 22.34.09 (full).jpg)
(2019-02-12 22.35.52 (full).jpg)
(2019-02-12 22.35.55 (full).jpg)
Attachments ---------------- 2019-02-12 22.45.36 (full).jpg (152KB - 108 downloads) 2019-02-12 22.23.17 (full).jpg (86KB - 118 downloads) 2019-02-12 22.24.35 (full).jpg (64KB - 110 downloads) 2019-02-12 22.34.09 (full).jpg (124KB - 129 downloads) 2019-02-12 22.35.52 (full).jpg (138KB - 100 downloads) 2019-02-12 22.35.55 (full).jpg (119KB - 119 downloads)
