Posted 2/13/2019 00:08 (#7317453 - in reply to #7316977) Subject: RE: Help!! 8760 hyd or trans problem
SE SD
We fixed a 8870 that the plastic hydraulic tank delaminated on the inside and plugged all the sump screens. Look like a plastic garbage bag on the inside floating in a he oil. They had a axle lube pressure issue. Then smoked the differential. Something to look at.
