NE IA | Yes you can make it work . No it is not a bud box and it will not work as well as if you did it like Bud said to set them up. So don't discredit the man's name and knowledge by calling anything less than his design a Bud box. What you have is going to take constant pressure and push to get cattle into the chute. Not what Bud was about at all' he was all about low pressure and stress on the cattle and to get that you need voluntary movement from the cattle. If you want to lower the pressure your pen is creating extend the pen past the chute and put a gate'( with the latching end of gate) at the alley going to your catch chute. This second pen should only hold what your alley can hold. | |
