Posted 2/11/2019 15:45 (#7314053 - in reply to #7312238) Subject: RE: Can a raven steer valve be made to run off an Ag leader system?
ROCKHAMPTON CENTRAL QLD
I ran a Leica valve (Raven Smarttrax) with a Steer Command for a short time seemed to work as it should. Only that I already had the Ag Leader valve I would have left the Leica valve on there. This was on a Ford 8870 though, not a sprayer. You would need to check what sort of override sensor Raven uses, might have to change it.
