Search Forums | Classifieds (144) | Skins | Language
Radar speed INPUT to FMX
tedbear
Posted 2/7/2019 12:53 (#7303761 - in reply to #7303364)
Subject: RE: Radar speed INPUT to FMX
Southern Minnesota Between Freeborn & Wells
Don't know about the FMX.
This can be done with an Ag Leader CAN system. A radar gun can be plugged into the 6 pin plug on an Auxiliary Input module or the 6 pin plug on the CAN switch box. The wiring is the same. The configuration can be changed to use this radar speed rather than GPS speed.
Another choice is to plug the radar into a branch of the Application Rate Module adapter harness. This method would be used if neither the Auxiliary Input Module or CAN switch box is used in an installation.
