case ih 1200pt and delta force
AVP_Matt
Posted 2/9/2019 11:25 (#7308791 - in reply to #7306157)
Subject: RE: case ih 1200pt and delta force
Hennepin, IL
That guy has a 215 Magnum, planter is something like a 2002 model with individual boxes. We have the same planter but no Deltaforce. Mostly all tilled ground and have nearly no issues maintaining ground contact. Now I'm trying to remember, aren't the lift cylinders double acting? If they are, that means it's actually lifting the whole planter up. An easy test would be to add a bunch of weight to the platform once its folded out. If that cures it, should be pretty easy to add some weight around there permanently.
Scratch that, I think those cylinders go into float when it's in the plant position. A fairly simple way to add weight to the bar would be to add tanks and fill them with water.
Edited by AVP_Matt 2/9/2019 11:32
