southern saskatchewan | Not sure if I can get any pictures sent but I think we have the first blade that got mounted to a 8870 with super steer. Had to remove the front weight mount from front axle so the blade could be mounted from the front frame and the rear axle. There is a extension on the rear of the dozer frame because the blade is further ahead and you need to change the steering stops so the front tires don't hit the frame. That was back in about 1996. Since then not sure if there we any changes. A call to Degelman in Regina Saskatchewan should help you they should have or did have a video of our tractor. | |
