| You do not need the foot switch for RowCommand clutches or variable rate. That 3 pin connector is only there if you add a rate controller to the planter for something like liquid fertilizer. It simplifies the install because you can connect the rate controller to the main CAN back on the planter and then plug your in-cab foot switch (master) into the main ISO harness on the planter at the hitch. | |
