Near Intersection of I-35 & I-90 Southern Mn. | raider2b - 2/1/2019 10:19
It is corrected to the fixed axle. Front axle on a 4wd and the rear axle on 2wd or mfd.
If I understand this correctly, the offset (left or right) would be entered into the Nav configuration. The NEMA output coming out of the Nav would have this correction applied so one should NOT enter a left/right offset into the InCommand configuration for that vehicle.
If the GPS source is directly from the GPS, (not going through the Nav) then the left/right offset should be set into the InCommand configuration. |
