South Georgia | I would be curious what would happen if you unplugged your brown box and plugged in a 2600 or 2630 display. Since you already have a GPS receiver, that might be the simplest option to make coverage maps. I think a 2600 display with no activations can be found very reasonably. Someone who is more knowledgeable about Deere displays could probably better answer this.
In that small cab you would be ahead to only have one display. You might have to pin out the coverage switch external trigger wire and use a relay to connect it to a boom valve so that the display would know when your boom is on or off. | |
