NW MN | If you have the very basic display cable for your Compass you will need to get two new display cables to do steering. The basic one would be the one that could plug into a cigarette lighter outlet.
The Compass uses the same display cables and plugs as the Insight, Integra, Edge, and Versa monitors. An adaptor cable is available to hook an InCommand to these display cables, but not the other way around.
Compass can use an implement switch when paired with an Application Rate Module. I have this system in a Versatile for coverage mapping with an air drill.
