Middle TN | Was thinking about trying some tramlines in soybeans with a 8/16 kinze equipped with vdrive. I see where one can set up rate sections, so I assume I can set it up leaving two rows turned off and split the population, from the rows turned off, to the two adjacent rows. In other words, if I was planting 100k, I could assign 150k to the rows next to the ones shut off.
However, my problem is that I would need tramlines on every third pass and the rows that need to be shut off alternate between 4/12 and 5/13. So, this would require three different setups.
Question is, will the gen3 allow one to save and switch back and forth between three setups. | |
