Posted 1/20/2019 08:34 (#7258097 - in reply to #7257441) Subject: RE: Lime: amount to use in no till vs. tillage?
South Central Illinois
Consider variable rate,
Herbicides and crops are sensitive to ph, both high and low,
I presume that there is some variation in your soil test results,
Long term, if you go with variable rate 1 or maybe 2 cycles, then you can go back to single rate.
