| So if I had a cruiser 2 running an old smartsteer system on tractor A, I could move that same cruiser 2 to tractor B which is running a Smartrax md system without having to change any settings on the cruiser 2? I could switch the cruiser back and forth with no issues loosing the calibrations and settings on either steering system?
I have a good working cruiser 2 and smartsteer system on tractor A.
I have a non working different cruiser 2 and Smartrax md system on tractor B. Not sure what’s wrong with it yet, the cruiser causing the issues or the Smartrax.
I want to take the working cruiser 2 out of tractor A and put it in tractor B to try to narrow down what’s causing the problems on tractor B’s system. But I don’t want to risk messing up the settings on tractor A’s cruiser 2 because it currently works well. So I should be able to put it in tractor B without changing anything in the cruiser to test system B and then put it back in tractor A like nothing happened? | |
