Posted 1/16/2019 13:12 (#7249202 - in reply to #7248829) Subject: RE: Duo-rate transmission
central, minnesota
I think the lower rate sprocket is just a hex weld-a-hub with whatever sprocket you need to get the percentage drop you want. The tables are available on the web site, but I cant get their website work. I or someone else on here could post the charts if necessary.
