| derby296 - 1/15/2019 23:15
You can run the ISO tab on a Run screen and can have your swath map in the LH area (the side of the 700 that doesnt change) most have been happy with this setup
+1.
The other thing that is commonly done is to view the as applied layer on the map, so you can see your lines and current rate on the same screen. You can also set up a TC Section status 2x1 soft key on any run screen, to monitor the section status’s. |
