Casey IL. ( I -70 ) then south on rt.49 | Yes done that years ago. I assume it is PTO. If so probably you got 2 choices dig . Or use a chain and pipe wrench around flighting. If will move easy you can use a pipe wrench on the PTO shaft. You get it out try and fix you a orbit motor on it instead of using the PTO then just reverse it. I have traded for one on my skid steer just for that reason. But you can make yours with orbit motor. Just find a real drive off of a old combine grain head. |
