| When I took top shaft out of tractor and started to disassemble it the red facings on the disk just started to peel off like dead skin when you have sun burn. I’m trying to upload a video but no luck Should I go with aftermarket or oem jd parts I’m about ready to hit my head cause it’s just begging to piss me more more off.
Ronn knows what I’m talking about I sent him a video of the facing just peeling off, the only thing I can think of is when dad got tractor back eight years ago and it would run hot or near hot side you could smell hydraulic oil from heat maybe that what caused it. I put new radiator thermostat heat cleaned the thermostat manifold and pipes and re painted with new shroud. Tractor doesn’t get hot anymore.
Edited by Kory20 1/11/2019 22:40
