mercer county, il | I would try to find one that does not have the cut edges, but whole rocks like the sides of that tile. Not to terrible to install, and those look slick/polished enough that getting the grout off should not be too big of a problem. tint your thinset or mastic the same color as you plan on for grout, that way any squeeze out or screw-ups don't stand out.
nope, not too hard to get the grout between the stones, just use your rubber/sponge trowel like a trowel, work at it 2 or 3 diff directions then peel of the excess and move on. it will take a lot more grout than you think, and a lot more will need to be sponged off to make it look right.
Edited by blowsand 1/11/2019 22:19
