Posted 1/11/2019 12:52 (#7237587 - in reply to #7237561) Subject: RE: Cummins 8.3 24V shutoff solenoid
There is usually a part number on the solenoid itself. A Cummins delaership or a descent fleet parts shop should be able to get you one with a part number or engine serial number. If you need to get the engine running, you might be able to wire the shut off valve with some steel wire or a zip tie or whatever you have around.
