Search Forums | Classifieds (162) | Skins | Language
Tmr mixer door
carlsoncl
Posted 1/10/2019 21:55 (#7236267 - in reply to #7235329)
Subject: RE: Tmr mixer door
Beresford, SD
I welded a chunk of angle iron on the bottom of my door when it started leaking. Put the 90 of the angle on top, Thought it would help strengthen the door as well. By the time I was done I had basically skinned the door and welded the angle iron on.......that was about 3000 loads ago. My biggest problem is my door will creep open as I'm mixing, I have to close the valve on the tractor and open it every load.....valves been rebuilt. I live with it.
