Search Forums | Classifieds (100) | Skins | Language
PP offset up bags
flyinfarmer
Posted 1/10/2019 09:30 (#7234533)
Subject: PP offset up bags
NE Iowa
Looking at adding airbags to my JD planter, and want up & down bags. Most every setup I see have the upper and lower airbags in line with each other. However, I picked up a set where the up-force bag is off set to the RH side (as looking from the rear) of the down-force bag. It has it's own lower bracket that ties into the lower middle screw of the upper bag bracket as well as the lower RH 'W-plate' row unit mounting bolt. Any reason to be concerned about the up-force bag being offset relative to the upper bag? Guessing PP changed it for some reason...
Thanks,
Chris
