Butterfield, MN | The manual you have is old enough where it's showing the old Viper II! Unfortunately, the plugs on the -256 and the -746 cables are different. Also, the configuration you mention with the Viper II getting GPS from port B of the Starlink receiver was a specialized setup, and it still required a lightbar to operate, so you're right back to square one. You'll definitely need a -746 cable to make this setup work. | |
