NC Kansas | assuming you are hooked to tractor? I think we were able to do this without trouble... used our skid steer for the hydraulic power. the wings stayed put and we basically let the center section float to the ground. To get the wings to "lower" the openers while folded up, we had to pin up the center section and use the skid steer to force wings to drop the openers. they won't "float" down folded up due to gravity basically.
I think I made that perfectly un-clear. We did the center section front and back, then pinned it up and forced wing openers out to work on them. reason for doing this is we didn't want to force the center section openers into the shop floor just to force the wings to drop.
Edited by KRM 12/13/2018 09:59
