Posted 12/13/2018 08:41 (#7168319 - in reply to #7168156) Subject: RE: Need the definitive answer on removing sealed bearings from shafts.
McCanna, ND
If the piece of equipment is within about 5 years of new it’s generally not to bad. Posi lock pullers are well worth the money if you don’t have any. Very seldom does the torch come out. I never reuse a bearing unless it about falls off or I can pull on the inner race. Pulling on the outer race can cause damage to the balls supposedly.
