Posted 12/11/2018 09:30 (#7163818 - in reply to #7163344) Subject: RE: CASE IH JX85 Electrical ???
Central MN
Based on that response, are you suggesting that it is possible that the system is not charging due to a bad connector on the dash for the "battery" indicator? Is it likely or even possible that a bad connection to this indicator would cause the system to not charge? I guess I can get along without a fuel gauge or the battery light but I DO need it to charge.
