Posted 12/10/2018 09:55 (#7161612) Subject: Irrigation setup for Fungicide, drops or traditional heads
Barryton, MI
Applying fungicide through the pivot. Does it make a difference on corn running a drop sprinkler that has full coverage at 96" high or using a traditional head mounted on the topside of the pivot water pipe? Does the plant above the ear need to be covered with fungicide from the tassel down or is above the ear sufficient?
