USA | pharmer - 12/9/2018 18:43
I read the post below about storing NH3. What are you guys doing in regards to storing 32% on the farm? What size tanks are the most economical and where do I purchase the tanks? Do I keep them under a roof or outside in containment?
What has worked and not worked for you?
Have 3000 gal poly tanks in shed plumbed together in one fill unload pipe. Can fill or unload from more than one tank @ once.. Reason for 3000 gals was cheapest cost per gal and that is what fit best in shed. They cost about $1200 each new. In ILL tank size above 5000 gal is under containment rules, under 5000 gal is not.
Edited by coup 12/9/2018 20:20
