Northeast Missouri | It's been awhile but if I remember correctly the pressure is around 1700 psi. The reel speed control knob on a 20 series combine is not connected directly to the speed control valve. There is a short length of hose between the two. The clamps get loose and sometimes allow you to change the speed only one way or not at all. A new hose and clamps will fix that problem. The hose was used to isolate some sound caused by vibration.
