Fruita CO | If you use the new shifter with the guide pin, use the whole thing, don't skip the guide pin. The new shifter isn't machined to be guided by the drum, & it will let the roller cock sideways & bind in the cam track, which is what the pin is designed to cure...with the new setup, it will shift better than it did new, as the roller will stay straight in the cam. You CAN use the old syncros with the new shifter, but the 3X5 syncros are better. | |
