Kansas | I spray with a pull type sprayer with a Raven 450 running through a JD 2600 monitor connected with the Field Doc Kit. I set up all of my chemicals in the 2600 as far as each amount per acre. I have imported that information into SMS and when I click on the operation or SPRAYING it shows the different chemicals applied as well as the date on the screen. It does not show the ozs, pts, lbs etc. Where do I find that in SMS? Is there any place that the EPA registration number can be entered?
THANKS! | |
