southern MN | There have been a lot of good threads in the past.
Here is one.
https://talk.newagtalk.com/forums/thread-view.asp?tid=724578&posts=1...
In general, the fcc allows so and so much power for you to broadcast your private internet per antenna.
You can make the beam a giant circle to cover an area, but it won’t go very far as the signal weakens fast as the circle gets bigger.
Or you can make the beam a pencil thin beam of concentrated power than can travel several miles, but it will only hit a far antenna it won’t cover any real estate at all.
You probably have to put together a beam system to travel the distance, and then a semi circle system to cover each yard.
Often setting up a tall 1/4 circle beam on a corner of a farm site will cover a lot of the yard area the best, if you have something to mount it to.
Getting through metal building walls or around groves presents another problem to jump with antennas and another setup.
Lots of planning and less jumps keeps it simple.
Sounds like you are not dealing with extreme distances, so it will come down to trees or hills or metal buildings that you need to plan for to accomplish the most with the least.
Paul
Edited by paul the original 11/29/2018 08:14
