| Yes you can delete out some stuff and help speed up your ipad...
Go to Settings/General and then you will see Ipad Storage...click on that. Depending on what IOS Version you have, I assume V11 or less since you say it's a little older...you will see what is taking up space on your ipad. The apps will be listed from the biggest files to lowest. Usually apps that have videos or pictures take up the most and are normally listed first. You can click on the app and it will go deeper and there you will have the ability to delete the app right there if you want. Just be careful to delete the stuff you don't use.
Hope this helps! | |
