Eastern Nebraska | I assume the data that is on the right is the main amount for that field. How many acres should that field be since you said that there's double the acres. As the previous poster suggested on the left hand side in the tree you'll want to find that specific load and right click it and hit "split load/region". This is assuming of course that you have a boundary for a field where that pass of data is. If it's touching that pass, it should send the data to that field. You can also manually move that data by working with the base map, but that is a little more involved. | |
