Hennepin, IL | Guessing so too, didnt know if he had the 10 or 20 speed. As far as your question, seems like you got it answered. Another option would be steercommand since your being quoted a 7500 anyways. The steercommand kit will be slightly less than the OT3, then you're just adding a valve. $3500ish should cover the valve IIRC. Those old GM steering columns can get loose and they're not the easiest to get the gear ring centered, hydraulic would avoid all of that. Just a thought, but then again it's not my money. | |
