| It seems at one point I did find a better way but it seems that whenever i’ve had this problem loading in from a pro700 at night after done for the day, I just go about the next day bring flash drive back out and either continue the field I was in or start something new. Just adding something to the flash drive. I would say almost every time it has worked when I tried it again after that next day, both fields will load in and bring me to current. Hopefully somebody else gives a little better technical insight but hope this helps. | |
