WNW Illinois, Henry Co | Did you by chance read job data twice, it sometimes will double the acres but not the bushels, if you still have the data on a usb stick, delete the layer in the tree, and read job data again to see if that works. other wise, i think you can go right click on the job, properties, and adjust the acres in the left column to get the correct acres, when you rubber band an area, is the bu/acres correct if it is then i think the base info is right but was double entered.
i just went into an old job of mine, right clicked to job properties, changed the acres and it worked
goood luck
bob | |
